Royal Enfield» Sixty 5- Cafe Racer
BerndM
Re: Royal Enfield» Sixty 5- Cafe Racer
Beitrag von BerndM »
You are doing a real good job. The dash board looks amazing. The gauges are extraordinary stuff.
kind regards from the other side of the Dümmer lake.
ILMARINEN
Beitrag von ILMARINEN »
Thank you very much, I'm glad you like it. It is not finished, in next week I will make a pink paste final polishing.
I want to install also four control lights
Regards for the other shore, andy
ILMARINEN
Hi
I made a new battery mount
Intersting, nice side panels. But wouldn't it be more pleasing to the eye, if the Battery was tilted the other way, following the edge of the side panel? You could also fully enclose it with an additional piece of bent Aluminium in the front, making a perfecttransition to the lids/panels.
ILMARINEN
Thank you, you're right. I moved it 3 cm back, I can not do more because there is a tire. Does it look better now?
Raul
Hmmm, it still seems a little odd. Isn't there enough space beneath the seat? Maybe if you tilt it a little?
Endert
Motorrad:: Honda CB 350/400 Four `72
Honda CRF 450 `17
BMW K100 `85
Yamaha TR 1 `82
Beitrag von Endert »
Why did you choose such a big battery? A smaler one would be much easier to hide!?
BTW, i like the side panels a lot.
Keep going. :prost:
mit besten Grüßen
Endert #76
Honda CX 500 Eurosport Umbau
Honda CB 350/400 Four Umbau
BMW K100 RS Umbau
I'd suspect the electric starter as a reason ;)
As these tend to fail and the kick starter is very easy to use, I'd get rid of that anyway, making the use of a smaller battery possible.
Plus it ads to reducing the weight!
But that is just my personal opinion.
"I see a blue battery and I want to paint it black."
(Surely not the Stones. :wink: )
ILMARINEN
I can not dismount the e starter, I have a unwell leg, I can not kick.
The panels come from the Moto Guzzi V7.
I've changed a bit, better?
Raul
Zurück zu „Royal Enfield“
