Seite 4 von 5
				Re: Royal Enfield» Sixty 5- Cafe Racer
				Verfasst: 19. Nov 2017
				von BerndM
You are doing a real good job. The dash board looks amazing. The gauges are extraordinary stuff.
kind regards from the other side of the Dümmer lake.
				von ILMARINEN
				Thank you very much, I'm glad you like it. It is not finished, in next week I will make a pink paste final polishing.
I want to install also four control lights
Regards for the other shore, andy
				Verfasst: 18. Feb 2018
				von ILMARINEN
				Hi
I made a new battery mount
				von grumbern
				Intersting, nice side panels. But wouldn't it be more pleasing to the eye, if the Battery was tilted the other way, following the edge of the side panel? You could also fully enclose it with an additional piece of bent Aluminium in the front, making a perfecttransition to the lids/panels.
				Verfasst: 22. Feb 2018
				von ILMARINEN
Thank you, you're right. I moved it 3 cm back, I can not do more because there is a tire. Does it look better now?
Raul
				von grumbern
				Hmmm, it still seems a little odd. Isn't there enough space beneath the seat? Maybe if you tilt it a little?
				Verfasst: 23. Feb 2018
				von Endert
				Why did you choose such a big battery? A smaler one would be much easier to hide!?
BTW, i like the side panels a lot.
Keep going.
				von grumbern
				I'd suspect the electric starter as a reason ;)
As these tend to fail and the kick starter is very easy to use, I'd get rid of that anyway, making the use of a smaller battery possible.
Plus it ads to reducing the weight!
But that is just my personal opinion.
				von Jupp100
				"I see a blue battery and I want to paint it black."
(Surely not the Stones.
				Verfasst: 3. Mär 2018
				von ILMARINEN
I can not dismount the e starter, I have a unwell leg, I can not kick.
The panels come from the Moto Guzzi V7.
I've changed a bit, better?
Raul
