Royal Enfield» Sixty 5- Cafe Racer
Re: Sixty 5- Cafe Racer
A little overweight, in my opinion. Why not put the ammeter in the headlight shell and the ignition switch elsewhere on the bike? The speedo on a nice small bracket and done. Or, if you want to, you could put a rev counter there.
Andreas was a little bit faster. My opinion is the same. It´s too massy. :wink:
...The ignition Switch I woul put below the tank.
What is the high of the speedometer? I Think, it´s not more then 25 - 30mm. May be you´ll get inspiration with these pictures. :wink:
it looks very good, only the screw that hold the ignition lock doesn`t match with the rest.
ILMARINEN
Beitrag von ILMARINEN »
I wanted to put a tachometer there, But I could not find a rev counter for one cylinder engine
The screw is old, I will polish it and add a black pad, the diameter of the ammeter disc
andy
Moin Andy,
take a look here
https://mmb-messtechnik.de/index.php?op ... 26&lang=de
ILMARINEN
Thank you, but I will make a lighter version of the bracket.
andy
[attachment=0]ROYAL półka, budziki.JPG[/attachment]
Matching your speedo:
http://www.ebay.co.uk/itm/REPLICA-SMITH ... SwHptY-xiA
Fitting it to the Bullet may require a bit of work, but It can be done. An alternative would be an electronic one.
@Sven: What do you want with such a modern instrument at this bike?
@Andreas: .daumen-h1:
...I would take the both Smith-Style instruments. For the housing I woul take a aluminium-tube with 1 or 1,5 mm wall-thickness.
For inspiration look here: https://www.caferacerkits.co.uk/shop/#! ... y=20704173
If you take a close look at this Royal Enfield Fury 500 Cafe Racer, you can see how the fitting of the tacho is done on the Bullet engine:
Fury
You'd have to fit an angle drive to the right hand cover and connect it to the ignition shaft.
ILMARINEN
Re: Royal Enfield» Sixty 5- Cafe Racer
I made a new speedometer casing.
andy
Zurück zu „Royal Enfield“
